Primary fuel filter housing replacement?
TexAndy
15
Bee County, Texas
So I got a forest service deuce and a half where they had removed the primary fuel filter and housing altogether. In it's place are fittings to bridge the gap between the hard copper fuel lines.
I looked at Jatonka's primary fuel filter spin on adapter but it looks like it requires the stock filter base to work. Which I don't have.
However, a few years ago I replaced my cucv stock fuel filter with a spin on adaptor from one of the big parts stores. Is there any reason why doing something like that wouldn't work on my deuce and a half? Or wouldn't be advisable?
Has anyone here done that? If so, which filter base did you use and why?
Thanks in advance
cattlerepairman
3,183
NORTH (Canada)
The main reason for using the stock filter base is to be able to return to stock condition easily.
No reason to not use a commercial base/filter combo instead.
I am curious to know what the Forest Service did on the secondary filter side. Did they perhaps put two spin ons in series to create an easily accessible primary/secondary filter setup? We do agree that the stock primary filter is...umm..ill positioned!!
The spin on conversion I use (from Westfolk) only has one secondary filter on a NAPA base and an adapter for the primary in the stock location.
Sent from my SM-G950W using Tapatalk
TexAndy
15
Bee County, Texas
It's going to be hard to return my truck to stock condition... it doesn't have a stock primary fuel filter base/housing.
They left the secondary and final fuel filters alone.
goodwithwood35
51
Bakersfield, CA
Napa 4309 is nearly a perfect fit, need to make a bracket. The lines might need a slight tweak to get them to line up, it wasn’t much work to make it work on mine. I borrowed the adapters from the old housing to convert the NPT threads on the housing to the line threads.
Katahdin
24
Scarborough, ME
I've used Bill W's technique on two of my truck, works great. Tip: Keep the bolts and plumbing fittings loose while assembling, then tighten everything down.
m715mike
3,822
Montgomery, Texas
Just got the wife to order Bill Ws' solution for me as a 29th Anniversary gift. I love that woman.... 8)
29 years, ugh? I bet you needed new filters.
(Okay, I couldn’t help myself.)
On a serious note, thank you for starting this thread. I have spin on oil filters and want to add spin on fuel filters. This information was helpful!
77 AMG
62
Owingsville, KY
LOL, m715mike. Agreed, thanks to TexAndy for getting this re-do thread rolling. Next up, converting the secondary and finals over to a more"field friendly" version......
