PRIMARY FUEL FILTER
24-VOLTS
Hey Guys,
Looking for a primary fuel filter housing. Or some help. Mine is leaking and can't get
her to stop. I have installed a new gasket and tightened it up with it still oozing out.
So unless I have missed something please let me know. Otherwise I was thinking of
replacing the entire unit to hopefully eliminate the problem.
Let me know if anyone has one available !
Phill
24-VOLTS
I forgot to ask if anyone is using a aftermarket product.
A spin on filter or something similar.
Phill
devilman96
17
Boca Raton, FL
look in the tech article section, I did one for changing the primary to a spin on filter... Check and make sure you have not accidentally installed a new gasket over top of an old one, its a common mistake and causes leaks as your describing.
24-VOLTS
Great !!
Thanks Devilman
Just to make sure the fittings from the existing fuel lines hook up with out any adapting ?
24-VOLTS
THANK YOU VERY MUCH !
I have printed everything out and calling my parts guy !
Thank you !
Phill
