Primer
zout
154
Columbus Georgia
When all surface is prep'd along with any bare metal surfaces use a 2K bare metal primer - that is your first layer of protective primer.
IF - you have imperfections in the surface @pits lay at least one coat of HIGH BUILD 2k primer on top of this. The bare metal primer does not get sanded unless you go beyond the window of getting the high build on - then it only gets lightly sanded @400 grit.
The high build you will be flat block sanding this to just about where it meets the bare metal primer - with this all your doing is leveling - then shoot your paint.
1,131
bryani289swmi
Dorr, MI
I would concur with the epoxy primer, it's a very good corrosion fighter. Good chip resistance and provides a good base for plastic body fillers. Thanks.
Bryan
