Priming for Gillespie
red devils dude
Ft Campbell
I was looking at auto paint books at the book store yesterday I couldnt
really find one I liked but then I saw a John Deere tractor restoration book
that had a ton of good paint info for stuff like you'd do for a MV like painting
over old solid paint in it they(the writers) said the only primer for less then
prepared surface was a epoxy primer so my question is what should work
better over a less then perfectly prepared surface a oil based zinc phosphate primer like Gillespie's Red Oxide III or a epoxy primer?
Low-Tech-Redneck
Red oxide primer has worked great for us, we bought it from, geeze, what was the name? Some auto paint and restoration place, ends with -wood...
EASTWOOD
They have a red oxide primer and rust encapsulator you can buy by the buckeload, did both the trailer and the truck before putting the GCI 383 on, to date, no rust and it's been outside all winter.
Low-Tech-Redneck
Nope, went over the truck from one end to the other with wire wheels, then did it again with a block sander untill there wasn't a jagged edge to be found. Depending on how rough and patchy the old coat was, sometimes that was just the last layer of paint, and other times, it was down to bare metal
Low-Tech-Redneck
The truck took about 5 days to completely do, clean, strip, prime, paint, and an extra 2 days for the trailer. That also included pulling down the troop seats, sanding, varnishing and painting those, and doing the same to the bows.
red devils dude
Ft Campbell
You know what the can of Gillespie I got must be off mine looks really dark, Are you sure it's 34086 I thought 34094
was the 383 green CARC-Substitute.
And I found I can get a PPG acrylic enamel for about $80 a gal(with hardener and flattening agent) in true 383 green.
Low-Tech-Redneck
Well, we ordered it through Army Jeep Parts, and that was the advertized number, they may have a mis-listing, I'd have to find one of the old cans and check it to be sure exactly what number it was, but it was definately some variety of the lusterless green, not the tan or brown kind from Korea or WWII era trucks.
Low-Tech-Redneck
Well, went back to the shop today, couldn't find any old cans :(
But I'm pretty sure that's what we used, I've heard the color can vary depending on a lot of factors and how many coats you put on.
DrFoster
Cheyenne, WY & Condado, PR
I use red oxide on bare cheap metal projects.
If you've got some "pings" in the paint from media blasting, or you want a LIFETIME paint job, use the epoxy. I used it on my friend's 997 Porsche and his Cobra Roadster and HOLY COW there is a huge difference.
Red Ox needs to have more coats put on, and it is easier to be sloppy with it. Epoxy required less coats and (I think) it was a little more forgiving since it was thicker.
