Priming the C12
JonM934
221
Herriman UTAH
I accidentally let some air into my fuel line and now the truck will not start. I think I found the priming pump but I do not know where the bleed screw is. Can anyone help me out with step by step instructions for priming the C12 with photos? Or if you have the MK23 repair manual I would love that!
MAdams
125
San Dimas, CA
I changed both my fuel filters(pre filled them before install) and my truck fired right up. There should be plenty of good info on the internet about priming a C12. They're a popular engine
JonM934
221
Herriman UTAH
I searched the internet but it seems these engines are not exactly like the civilian models. The youtube videos show engines that I see look close but it is not the same as my engine.
snowtrac nome
137
western alaska
the fuel system is a common rail style so you just pump the primer and the air will return to the tank through the return line, you can also crank it to force fuel through, it is self bleeding but its hard on the starter.
JonM934
221
Herriman UTAH
snowtrac nome, I agree with what you are saying. The problem is the pressure regulator will not allow fuel to pass until it has built up a lot of pressure. I tried to use the prime pump and I even backed out the regulator bolt to bypass it but the fuel is not flowing. It might be that the prime pump seals are shot. On the internet I see that is a common issue.
I also tried cranking and I cranked for a long time, pausing every 30 seconds as the manual says to. But still no luck.
I have found a mobile diesel mechanic that is an expert in Cat engines and he is going to stop by tomorrow. While he is here, I will ask him some other questions that I have.
snowtrac nome
137
western alaska
I've never messed with the c 12 engines bit the c-9 s I messed with I have blead them that way. The excavators all had an electric pump on them to bleed them. if I had to I would likely crack a line where the fuel enters the head , once you have fuel to the gear pump it will push through about anything
JonM934
221
Herriman UTAH
The mobile mechanic stopped by and we could not get the truck going. There was air getting into the line somewhere. It must be the water separator but we could not figure it out. He did tell me a lot of interesting things about the truck. One thing he pointed out to me was the Ether assist to get the truck started when it is cold. I always wondered my the truck was so easy to start when it is so fricking cold outside. Now I know why. I guess I need to replace the Ether can once in a while.
JonM934
221
Herriman UTAH
I got my truck started and I can drive it again!!
So I found a lot of instructions on the internet and even in the MK23 reference manual that is in the upload section. Most of it was wrong. I needed to take bits and pieces from many sources to finally figure out the proper way to prime this machine. I will make a video about it because it is complex.
wheelspinner
1,518
North Carolina - FINALLY !
Did you do the video?
Nathan P
Mississippi
When I got my MTVR, the only way I could get it primed was to have someone pump the priming pump until the fuel began to bypass and keep pumping while I turned the engine over. Using this method, it started right up and I’ve never lost prime.
IridiumRed
37
NW MO, north of KC
I need to change fuel filters on my Mk25 in the next few days (just doing long term maintenance, shes working well but no idea how old these filters are, they are as she came from .gov). Am doing both filters fine filter on engine + coarser one/ water separator). I assume ill lose prime* when i do it. Ill make some mental notes on what it takes to restart it, write it up sometime.
Personally im planning on just using hand pump after filters are changed. The one on the engine, i may leave just lightly hand tight... and after some hand pumping, crack it loose, let air escape, retighten lightly, hand pump, break loose and let air out, repeat process until its just fuel coming out (i suspect it would be easy to get big air pocket in system, "burping" it like that might get it to where its mostly fuel, this has been my experience w other diesel engines, that you need way to get air out... which sometimes is essential, sometimes the engine can crank through the air, get running, bleed itself). Might also just leave engine filter barely cracked loose, pump until fuel comes out there.
Im not sure if the pump is upstream or downstream of the engine mounted filter in respect to fuel flow to the engine. Its something that i could figure out, just dont have it in front of me right now. But how its positioned could determine whether having filter slightly loose would suck air in or let air push out. I think its the latter.
If i was in a real hurry, id probably prefill the fuel filters (VERY CLEAN FUEL ONLY), install, pump until decently hard, then start engine let idle a bit...
ANYWAYS! Ill be doing this soon, ill take mental notes on what worked, and ill share them here :) Ill follow through on that. Just be good information for us to have available. Trying to prime diesel engines can, as a whole, be a frustrating and variable process from one model of truck to the next. Some needing very particular steps, others not caring much...some in between
Notes -
By losing prime in this case (swapping fuel filters), the fuel system will prob be dry from engine mounted filter back to the tank, but there should still be fuel in a lot of the engine. Fuel pump to injectors should still be full. This is not a "complete loss of prime" like if you ran engine out of fuel or took a bunch of fuel system components apart and let them drain... and who knows what condition the OP's truck was in. Not sure if there are anti drainback valves in the fuel system / where, but wouldnt surprise me. That could influence some of these things...
Above when i just say "pump" im referring to hand pump
