priming the pump
tokarev
Safety Harbor Florida
The fuel pump on my M35 stopped pumping - still made noise like it was working but no fuel output. Removed the pump to find the pump unit was frozen up - more like gunked up. After removing the lower part of the pump and washing it down with some MEK it finally freed up. We reinstalled the pump and fuel flow returned. Now the question - Priming the injector pump - Is there a trick to getting the injector pump primed? Bleeding air at all the filters untill theres a steady flow of fuel at each?
JAYHAWK 1962
tijeras, nm
Had the same problem with one i bought switched out the in tank pump let it run for a minute or two and cranked it for a 5-6 seconds after the fourth sequence started right up have not had any problems since
