Probable Blown Headgasket
gijoe13
Eliot,Maine
I have a 1974 m35a2 with a white manufacture engine. I am getting antifreeze out the slobber tube. I am thinking this means a blown headgasket. There is no antifreeze in the oil that I can see from the dipstick. Any thoughts appreciated from all of you that know much more about these trucks than I do. I am slowly learning and having a great time with my stepdaughter working on it together.
Thanks, Jeff
OPCOM
27
Dallas, Texas
green coolant coming from inside the slobber tube? The tube comes from the rocker cover. How lmany miles has this been going on for? If you have enough cooland in there to notice, you should be able to find it in the oil. Could it be running down the tube from underneath? Maybe it is leaking externally to the engine or spraying from a freeze plug under pressure? Does the oil look fine after running the engine?
JDToumanian
14
Phelan, CA
I think Patrick is probably right.... I don't see how you could have coolant coming out that tube without the oil on the dipstick looking like tapioca pudding.
Jon
gijoe13
Eliot,Maine
I agree with you all. I cant understand how there is no sign of coolant on the dipstick. The truck is new to me a year ago and has no brakes so havent run it for long periods, just to move it to work on it. It sat for five plus years before I purchased it. Could it be coming from the turbo? Is that cooled by antifreeze? The truck runs great otherwise. Thanks for all the comments so far. I will try to get a pic of the dipstick later today.
1,175
No, it is not.
gimpyrobb
dumpsterlandingfromorbit!
27,785
749
Cincy Ohio
There is coolant passageson top the motor. When mine leaked, it got on the slobber tube somehow. Have you checked to see how tight the top coolant passages are?
