dmetalmiki
- 2,028
- 113
- London England
I have an RPM problem with the 5 ton M54a2 running all over the place..sometimes ok sometimes stops sometimes runs lumpy and then usually stalls out.
we changed the in tank pump to an all singing and dancing aircraft type replacement. changed all the filters, and the hydraulic head. Then the hi pressure inlet pump on the side of the injection pump. Still no go.
When we bleed at the filters it runs fine..for a while, then "here comes lumpy" again!.
I then changed the rubber inlet pipes...no different.
A little bleed, and fine for a while.
Frankly I am beat, so any advices appreciated.
