gsxrinthe9s
- 0
- 0
- fairfield,ohio
76 dodge ambulance having problem with all lights going off then back on after about 30 sec then back on and off again. not sure where to start looking
This is true, to a point. These issues may or may not be related. The circuit breaker may be being tripped simply because of its age. A "weak" circuit breaker by itself should not cause the battery to go dead, but it will cause all the lights to keep going off and on by itself like you described.i have been thinking im not sure the circuit breaker being bad would make the battery discharge when not in use would it ? but what ever is overloading the circuit breaker could be whats causeing the battery issue. whats you guys thoughts
