Proper size lugs for singles on HEMTT rims?
Yohan
Does anyone have a part number or measurments on the proper length, thread pitch, etc. for replacement studs for HEMTT rims run on a 5 ton? I read that to safely mount the HEMTT rims on an M809 series truck, the studs should be longer and this would only apply to the rear tandems (?). MASIC mentioned he used Kenworth studs and offered the part number, but I have not been able to reach him.
I want to do it right and any help would be truly appreciated. TIA...
John
73m819
325
gainesville, ga.
It applies to the front as the front stock studs are to short. the studs have a standard pitch, measure what length you need then go to a big truck parts house, thay should have the needed studs in stock, take a stock stud with you, tell them you want the same stud only longer by so much. don't forget you need both left and right threads
Yohan
The thread on SS I was referring to was a very interesting one, but what you said makes very clear what I need to do. And to make sure, the studs on the tandems will be the proper length and should be safe to use as long as they are in good shape, right?
I thank you very much for your help, sir! :beer:
John
73m819
325
gainesville, ga.
John
I think so, but would not hurt to check just to be sure
