dodjh
- 14
- 18
- Central, MS.
Hi, my PS fluid is milky and I wanted to change all the fluid in the pump and steering sector. Removed only line on the steering sector
that would come out (first jacked up front end) and turned steering wheel back and forth. Emptied pump reservoir several times
before reconnecting line on steering sector. Filled up pump reservoir and started engine. Whines when I turn wheel right to left.
Turned off engine and checked reservoir...milky again but hadn't lost much fluid.
Does the steering sector take different weight oil as opposed to PS fluid and if not why the whine with full reservoir?
