PTO and Winch Questions
CloverFireCo
Heckscherville, PA
We have the M813A1 pictured in my profile there.
An M39 series truck showed up at our fire company with a winch that we would like to remove and install on the M813. I was told to look to see if the PTO was the correct one to fit the M813 and I do see in the TM's that there were 2 different PTO's but no way to differentiate which PTO goes to what truck.
Hopefully simple question, will the PTO from that M39 multifuel fit our M813/M809 series truck, the transmissions are definitely different on the 2 trucks, the multifuel has a standard shift pattern and our has that odd-ball placement for the 4th and 5th forward gears, but the transfer cases look exactly the same to me.
I know, definitely not enough information here, but is 2am and not going down to copy numbers or take pictures.
Chris
Desert Deuce
17
Chino Valley, AZ
Everything will work except the driveshaft, you are going to need a longer M809 driveshaft.
You can also have the M39 driveshaft lengthened at a driveline shop.
