PTO Generator for M35A2
SW2Junior
Did they ever make a Generator for the M35A2 that would operate thru the PTO? I have a Deuce, need a bigger Generator and thought he would be a good power source but before I reinvent the wheel is there one out there? Thanx
rchalmers3
30
Irmo, South Carolina
I don't have an answer to your question, but i have crawled around under a few of these and I'd suggest you consider fitting a transfer case PTO instead of the transmission PTO.
You will have more space under the bed than if you try to fit a front and/or rear facing Transmission PTO.
BTW, what size generator are you needing? I like the deuce as a work platform, but the possible inefficiencies of the big motor incorrectly matched to the load give me pause.
Best regards,
Rick
