PTO part needed
emmado22
147
Mid Hudson Valley NY
All,
Im looking for a part out of a winch PTO WND-7-28 from a M35A2.. I need the long shaft that slides arround inside the PTO that has the 2 rubber boots on either end. Mine is scored, does anyone have one thats in used, good shape? Memphis wants crazy money for the shaft....
I also need the eyebolt that connects to the linkage...
Also looking for an PTO cover plate that goes on the tranny for a NON winch M35A2
Will pay for parts and shipping...
Thanks!
Mark
sermis
17
Temple, TX
Clean it good, JB Weld and sand it down. 2 new seals and you are done. No more than it will be used it should be good to go.
Other option is to weld it up and then have it turned back down to correct size.
ida34
33
Dexter, MI
I got a PTO from Kenny awhile ago and it arrived damaged. I got the check from FedEx and I think he got the PTO back. He may be able to come up with your part since the case was the only thing damaged. You might check with him.
1,808
I knew you were going to throw me under the bus Chuck. I still have the PTO and I have a case coming for it next week. The case may still have some parts in it so I'll have to check it.
ida34
33
Dexter, MI
It would be ashamed to let all those rebuilt parts go to waist. I would have looked for a good case also if I was you. I just wanted to help you boost your post count.
