PTO question
moreorles2
Freedom, NH
Guys- I did RTFM and cannot even find the part on the drawing. I have installed the PTO on the tranny and noticed that there appears to be a leak from this nipple/stud on the bottom of the PTO after a couple of weeks.
There is no reason to put a drain plug on the PTO so I have no idea what it is or what function it performs. Can someone enlighten me and is there a gasket or oring sealing this to the PTO housing? Thanks----> Les
Piix's attached-(This is a file pix and not my PTO)
emmado22
147
Mid Hudson Valley NY
That fitting houses a spring and detent bearing that "clicks into" the cutouts on the shaft #25 when you move the PTO handle. Only thing you can do to stop it from leaking is drain the tranny, take that off (make sure you catch the parts inside, clean it, and RTV it.
While you have it drained, undo the drain plug? (part #16), clean and RTV it also. You'll find after doing both of those things, your drips will stop. (dont ask me how I know)
Tranny takes 80/90 weight oil as per the TM.
Let us know how you make out.
moreorles2
Freedom, NH
Thanks Emmado22. Taking a second look at my figure #12, what you have pointed out is identified as parts #18-19-and 20 that I thought were internal to the PTO.
I'm once again off to NAPA for some fresh RTV...... :)
emmado22
147
Nope, just gently unscrew the "cap", and the spring and ball will come out. The spring is under some tension, so just catch it when it comes out. Let it drip for a bit, clean it real good, RTV the capand put it all back together.
With the drain plug, remove it, let it drip, and reinstall with RTV.
That should fix those drips. Why the cap thing was never sealed with a copper gasket or RTV or the like in the first place is beyond me..
Good luck!
