PTO Shifter handle
whall4
Crossville, Tn
I have just recently added a pto to my duece and now I need a shifter and linkage. I have been looking online trying to find one to buy but haven't had any luck yet. I have been thinking about just making one. I could use a push/pull cable shifter, i guess, but would rather have the "regular" shifter handle
I was wondering if anyone has made a shiter handle from scratch, or maybe has the dimensions for one? A couple of pics from different angles of one already installed would even help. It's a tight area so a straight handle wouldn't work, or I don't think it will.
gringeltaube
Staff Member
2,519
Montevideo/Uruguay
......... but would rather have the "regular" shifter handle
TNJMURRAY has it listed here, NOS with the correct NSN, but the image shows a TC lever...
I would check with them, just in case.
Of course that handle can be reproduced exactly, but for that you should have one complete assembly to copy from, rather than go from drawings/pics.
Besides the short rod (NSN 2520-00-706-1230) you may also need the corresponding bracket (NSN 2520-00-622-3927), which mounts to the master cylinder.
whall4
Crossville, Tn
Thanks topo for the reply and pics. An air shift setup would be nice but I like the simplicity of just having a manual shift lever. There isn't much that can go wrong with it.
Thanks for steering me in the right direction, gringeltaube. I will contact them to make sure it is the pto shifter before I order it
