Pushrod hydraboost is leaking
mezc
bakersfield,ca
Steering and breaks are working good, I used a quart steering fluid every week (500 miles) to refill it to give and idea of the dripping. I put ½ quart of lucas steering stop oil and the leak slow down pretty good but still dripping.
Of course is annoying having oil inside the compartment but I do not want to go for a whole hydroboost change ($100 bucks + ) now.
Seems the pushrod at the pedal has a C clip, can I take this out and replace a simple packing or an o-ring to stop the leak completely?
ida34
33
Dexter, MI
You can replace the bad seals and o-rings with a kit that you can use to rebuild the hydroboost but as for just sticking something in there to get it to stop I say know. Were talking brakes hear. If you are short on cash get the rebuild kit and do it yourself.
emmado22
147
Mid Hudson Valley NY
hydroboost = brakes
bad hydroboost = questionable brakes
questionable brakes = impending disaster
If you cant scrape together $100 for good hydroboost, you really need to not drive the truck until you can.
mezc
bakersfield,ca
My original question is, if I take the C clip with the hydraboost in place, remove the push rod aside, is there a o-ring that I could easily change?
