Hello once again. I tried searching. I beg the collective for some more of your fine advice to help me avoid wasting tons of $
Before I upgraded to a 200 AMP generator, the Wait Light did not light for the last couple months. I would wait a minute after turning to run and the truck would start normally. I added the 2nd 12V lead to the battery from the 200 AMP generator in addition I installed the new 24 cable supplied in the kit.
So now I am looking at the wait light. I tested the original wait light with a separate 24 volt supply and it was burned out. So I replaced the wait light and the new one lights with my test 24 source. But when I installed the new wait light it would not come on. Seems like the plus lead is hot with ignition on and the ground is switched by the PCB? There is infinite resistance on the ground lead to the light. If I temp ground that negative lead to the installed new light, it lights.
So does the PCB switch the wait light on via ground?
FYI I have installed a LAU Distribution Box, NSN 6110-01-446-7126, which I do see are no longer available anymore.
I searched for some business that "rebuilds" these but I am not finding one? Seems like it could be a lucrative business.
So which PCB is the go2 one if I have to get a new one? Seems the Nartron S3 Smart Glow Plug Controller Protective Box at the "bargain" price of $700 is the cheapest. Is this ok for a '92 M998 NA 6.2. I guess I should replace the glow plugs at the same time?
![20231111_093612.jpg 20231111_093612.jpg](https://www.steelsoldiers.com/data/attachments/665/665575-ba7ceeb9c5c32e683e5b2443c0e79801.jpg)
The officer I purchased the M998 from replaced all the glow plugs and PCB before he sold it to me, well according to him anyway. I guess he replaced it with something old (used) he had laying around.
I do NOT have a spare PCB, and seeing they want about $1K for one I don't want to buy one unless I am absolutely positive and not just through extremely expensive parts at it
Please give me your advice on how to proceed. Thanks in advance!
