Question about MaxPro wheels
Olly
Bristol/CT
I was wondering if the dual MaxPro wheels are the same measurements as the stock m800 5 ton series wheels? Mainly was wondering if the offset was the same. From what I could measure my wheel itself is about 8 inches and my offset is 3 but because its still mounted on the truck its a little difficult to get an accurate measurement. Any information about measurements for either wheel is appreciated. Thanks
simp5782
Feo, Fuerte y Formal
9,369
Mason, TN
Yes they are budd pattern. There is a thread on this already. Studs will have to be super long to work. Limited on tires you can mount on them as well.
Olly
Bristol/CT
Thanks for the quick response I did know they are a Budd pattern and I have checked several threads none mention the exact backspacing.... from the measurements I have gotten about the Maxpro rim is that they're ten inches total which would mean they have a two inch offset and as I have not found the exact offset of the stock 5 ton rim I was wondering if they have the same off set?
