Questions about Starter and flex plate for M1009
ida34
33
Dexter, MI
Is the civy and military flex plate the same? Is the starter the same except for the actual motor being 24v instead of 12v? I have a new starter with a cracked nose and possible a bad bendix. Can I salvage this stuff from a bad 12v civy starter and put them in the 24v starter?
Anyway I need the following if anyone has it let me know a price.
Flexplate
Starter (even a bad one will do)
Driver's side window
both doors
tailgate
tailgate window crank
any front floorboard patch panels
rocker panels
inner fenders especially the passenger's side.
Glow plug controller.
Chuck
M35guy
I think the body parts can be salvaged from a civvie truck, the motor parts, I dont know about.
mangus580
282
Western NY
Flex Plate is the same, the nose cone on the starter should be as well. Not sure on the bendix, you can compare them, but I would suspect they are.
all the body parts, and glass, is the same as any 81-87 (92 for blazers and suburbans) civvy model. (Passenger inner fender might not have dimples/holes for the battery trays, but will work)
The Glow Plug controller can be purchased brand new from www.flmv.net, or refer to the Tech Article section for instructions to convert the controller to the civvy style, or to manual.
rizzo
Port Huron, MI
I have a M1008 w/bad engine so I decided to put a SB 350 in it. The torque converter would not bolt up to the flex plate of the 350. I don't think the flex plate would bolt to the 350.
So does that mean the Olds and Chevy flexplate is different?
mangus580
282
Western NY
No, what it means, is the Torque converter for the diesel is different than the gas. The diesel converter has 6 bolts vs the 3 of the gas. I think they are also at a different diameter.
Where does Olds come into play here?
mangus580
282
Western NY
HELL NO!!!!
350=5.7
the 6.2 and the 5.7 olds diesel are NOTHING alike :)
BTW.... for that 1008, why not pickup a surplus engine to put in it? Might be easier in the end :)
rizzo
Port Huron, MI
mangus580 said:
HELL NO!!!!
350=5.7
duh
too late already have a gas in it. I think you are right though.
ida34
33
Dexter, MI
It is a very common misconception that the Chevy diesel is actually the olds diesel that olds used. It is wrong but common. I think it comes out of the fact that in the early eighties GM started combining engine types and put engines from different manufatures in different cars. IE chevy engine in an olds and such.
Mike,
It looks like it has already been converted to manual operation. There is one of the big starter type pushbutton in the radio cover plate. How do you run this setup? Do you just push the button in for a few seconds then try the start?
mangus580
282
Western NY
yeah, Pretty much. Just make sure that you dont hold it too long, unless you know that you have self limiting glow plugs in the engine.
Armada
Buick City, MI
The 6.2's are Detroit Diesels made for GM. For 80's technology, it is a very good engine. After GM's debacle with the Olds "gas converted to diesel" engines, their reputation for diesels had already been tainted, so the 6.2's don't get the credit they deserve.
