roger-wilco-66
- 0
- 16
- Karlsruhe, Germany
I understand that the sprag t-case has to be "prepared" for reverse into forward operation by shifting rev into the first gear and vice versa, hence the linkage between the transmission and the transfer-case.
But I see that with the airshift-type there is no mechanical linkage between the transmission and the t-case. It is not clear to me how this operates: how does the airshift t-case switch from forward /reverse operation?
Another unclear thing to me is what happens with the sprag transmission when I start in the second gear from reverse, omitting the first gear and therefore drive forward without putting the t-case in to forward operation. ''
Thanks for the answers,
Mark
Mark
