RickTheEngineer
- 5
- 16
- Mount Laurel NJ
Howdy folks! I have a question involving the replacement of a carrier for an aftermarket locking differential. I want to keep the ring and pinion gears since I want to keep the stock 3.06 gear ratio found on the M1009 in its stock configuration. I see a lot of information involving the the preload on the pinion. I should not have to worry about this since I am only replacing the carrier right? Also, I did see some lots of words of caution involving shimming the side bearings to make sure the contact pattern is correct between the pinion and the ring gear. How do I know if I have enough preload on the side bearings? (or am I getting something mixed up?) Also, I could not find a TM that went into great detail on the removal of the diff itself. I did see TM9-2320-289-34 Paragraph 6-1 and I still can't figure out how to do the entire process before I start (like what I have to remove before removing the side bearing belts). Any advice? Thanks a lot! (thinking about getting an OX locker).
EDIT- also does a GM 10 Bolt have axle shafts that slide out? Do I have to remove anything more than the tire for a job like this?
