Quick alternator question
tmclean
yakima, wa
Back again. I decided to take my passenger side alternator apart to figure out why it is not charging. Got inside and found a small spring bouncing around and a broken piece of metal that resembles a magnet just to the left of the resistor. If I did things correctly, I should have a picture attached. Im just wanting to know what the part is called so I can fix this thing.
rtk
449
Lockport N.Y.
If I follow you correctly , that is the brush/regulator assembly , use a drill or paper clip to hold the brush's in (2 small holes) when you assemble the unit to the rotor . I am not sure what you can "SEE" , but there is not much you can check with out some equipment . Parts are available for these units .
Warthog
244
OKC, OK
The TM 9-2320-289-34 has detailed instructions on the alternator and the TM 9-2320-289-34P parts manual has detailed parts list.
When you opened the alternator the brushes popped out. They weren't just flopping around inside.
Get a rebuild kit from www.aspwholesale.com since you already have it apart. Take pictures of each item you remove so you can know how to put it back. You want a Delco 27si type 100 kit.
Warthog
244
OKC, OK
Someone has been in the alternator before, the flat blade bolt on the brush holder is not stock.
tmclean
yakima, wa
Okay okay I get what im looking at now. It is a remanufactured alt done by CME ARMA, INC. Apologies for my silly questions as this is my first time taking one apart. Id normally just buy a new one and install it but am finding gratification in actually FINDING the problem and fixing it. Its a little easier on the wallet as well. Ill rebuild it and see if that solves my charging problem.
