Quick Rear Main Seal Question
BobMassive
Chicago, Illinois
Hey all. So the TM -34 references a pipe sealant used for mating the lower seal half to the bearing cap. The FAQ does not. Is this a necessary step? If yes then what exactly is the correct sealant? Plumbers sealant or silicone sealant? I don't want to use the wrong stuff and end up re-doing this. Also while I'm at it how critical is it that the seal be installed at the 2 o'clock 8 o'clock position?
Ken_86gt
Williamsburg VA
If you follow the 2 & 8 o'clock you minimize the chances for oil leaking by the seal. I used a very small dab of black RTV on the end of each seal where they will touch. I also used a very small amount of an anerobic sealant between the block and bearing cap. When all done I let it cure for several hours before attempting to start the engine.
BobMassive
Chicago, Illinois
Thank you. So you did not put any sealant in the groove the lower seal part sits in? Or am I just misreading the tm? In other words, the lower seal is just pressed in.
pigfoot63
Gainesville, Ga.
I have installed the seals two ways, flush mounted with block and cap and as you mentioned at 2 & 8 I never had any trouble with either method. However I can see why the 2 & 8 method gives you a better seal. I use Permatex ultra black silicone when I install mine, just a dab on te ends.
lavarok
33
Fellsmere, FL
I am pretty sure any rtv on the seal itself is a no-no. However, that is not to say it might not work. I've done a few and followed the TM to the letter, I also wrote the wiki article you reference.
