Quick vin question
silverbullet72tnt
Northern NH
Not sure which one is my vin number. My data plate is as follows:
Stock number: G2742-8358464
Ser. No. (No stamping, it’s blank)
MFR SER NO m-32819
Cont. No. da-11-022 ord-735
I’m not sure which one or combination is my vin number
silverbullet72tnt
Northern NH
Thanks so much. I’m new to these trucks but I’m already in love with mine. I really appreciate this community as well!!!
Above that info it says truck cargo 2 1/2 ton 6x6 m35 w/wn
Does this mean it originally had a front winch? It doesn’t currently but has a pto. It will be getting a winch after I get it running
NDT
6,280
Camp Wood/LC, TX
If you have a pto with a shift lever sticking up near your right leg, and the data plate says w/wn, then yes you should have your winch back!
silverbullet72tnt
Northern NH
Any idea if there is a 2018 VIN thread? I searched VIN stuff on here and found a dead link to the carnac thread, then a locked 2017 vin thread. Then I came up empty after that....
silverbullet72tnt
Northern NH
Any other ideas to find out more on the truck? Its my first MV and I am dieing to know more about its history etc. It ended up as a forestry truck at some point in life, its still painted on the doors
NDT
6,280
Camp Wood/LC, TX
If it's a gas engine truck still, it will be too old to show up in the database that the "VIN info thread" uses. If it is multifuel, wait until the thread opens. Your truck was gas powered at one point as the serial number is pre-diesel I believe (1950's).
See if you can find 2" numbers painted on the hood sides under the forestry paint job, this is the Army registration number and is a clue to the truck's history.
1,807
It's a Stude. Check the frame stamping. It's right in the area of the LF fender support.
silverbullet72tnt
Northern NH
Ill have to check when its actually here. Getting towed saturday afternoon I hope.
Will the number on the frame be the missing serial number? or will it match the manufacturer serial number?
NDT
6,280
Camp Wood/LC, TX
Not foolish at all! This is very specialized information that can only be found here on this website.
