readyman
- 7
- 18
- Elk Grove Village, Illinois
After cruising for a while at highway speed. A mile or two before running out of fuel I noticed a mist, then a spray, then streaming fluid coming from under the hood. It was streaming from the hood side panels across the fenders, on the windshield. Well then the engine stopped and the fluid leak took second to rolling as far as possible towards an exit.
After getting back to the shop I tried to trace down the coolant leak. Well to make a long story short, the radiator cap drain tube was completely plugged, every inch bottom to top! The coolant overpressure was blowing coolant thru the cap, hose connections, gaskets, it was all over. I could not ream the drain tube out because of the sharp turns in the tubing so I cut it near the cap and replaced it with some nylon flex tubing, and it won't corrode.
So a word to the wise, check your radiator drain tube, it could be a mess later otherwise.
