Radiator Hose parts # Cross-reference ??
heavyzee
Houston, TX
I reviewed the TM and found the NSN and PN from there, for the replacement radiator hoses. Do any of y'all have Napa cross reference part numbers or other parts store? I tried cross referencing using Napa and WB Parts.
I searched the forum for about an hour before posting, so apologies if this has come up all ready
Z
1 PAOZZ 4730002043491 66295 C32P CLAMP,HOSE.......................... 2 2 PAOZZ 4720011883909 19207 12339160 HOSE,PREFORMED INLET............... 1 3 PAOZZ 5310000614650 96906 MS51943-31 NUT,SELF-LOCKING,HE................. 2 4 PAOZZ 5310011023270 24617 2436161 WASHER,FLAT......................... 4 5 MOOZZ 06968 42130156-7 PAD,CUSHIONING MAKE FROM PAD,P/N 2 12339902-1,5.6 INCHES LONG.......... 6 PAOZZ 5305000680508 80204 B1821BH025C075N SCREW,CAP,HEXAGON H................. 2 7 PAOZZ 4720011873386 19207 12339162 HOSE,PREFORMED LOWER............... 1 8 PAOZZ 4730009098627 76599 36HSS CLAMP,HOSE.......................... 2 9 PAOZZ 4820007529040 93061 DC603-2 COCK,DRAIN.......................... 1 10 PAOZZ 4710011880028 34623 5578604 TUBE,BENT,METALLIC LOWER........... 1 11 PAOZZ 4730013299151 7Z588 CT250L CLAMP,HOSE.......................... 2 12 PAOZZ 4720011881370 19207 12339159 HOSE,PREFORMED...................... 1
Stonewall
Peoria, IL
I do not think there are civilian part store interchanges. Just order from the popular auction site or one of the HMMWV parts vendors. They are readily available and not that expensive. hummerpartsguy.com is a good one.
86humv
497
Texas
Hoses are the same on early H1's
But cheap on fleebay
heavyzee
Houston, TX
well Rock Auto has all the parts
Lower Radiator Hose - Engine to pipe - Gates 22649
Lower Radiator Hose - Pipe to Radiator - Gates 20685
Upper Radiator Hose Molded - 20974
Upper Radiator Hose Straight un-cut (1-3/4" hose) - Dayco 76175 (Comes in 3' Lengths)
