Radiator Stop Leak question
JackMurphy
San Francisco
Hi all, so I have an anti-freeze leak due to a crack in my radiator and I read really great reviews about this stuff. I have questions though as the instructions are unclear and my knowledge woefully incomplete..
1. It says to mix 1 pint (1 container) into 1 gallon of anti-freeze/water mixture. Obviously my vehicle can't hold all of this at once. Do I still mix all both containers and just keep the mixture handy to re-add, if necessary? (or should I only ratio out the minimum needed to hit my fill line and keep the two components separate until future re-use).
2. Does anyone know how long this stuff tends to last for?
3. Any success stories out there?
cucvrus
10,501
Jonestown Pennsylvania
Stop leak is a myth. No such thing. Get the radiator replaced or fixed. Stop leak will fail you and you at the worst time. Solder is the only stop leak I trust. And only when properly cleaned and applied. Good Luck.
porkysplace
1,496
mid- michigan
Unless your in some remote area and need to do something to get home I wouldn't use any stop leaks . They are a temporary fix at best what will also plug things like your heater core that you don't want plug . Either pull the radiator and take to a reputable radiator repair shop and see if they can fix it or buy a new one.
DeadParrot
47
oklahoma city, ok
Stop leak can work, but it should be considered buying time while you gather parts for a proper fix. Also plan on doing a full flush as part of your proper repair. I used some on a 75 C10 with AC to shift the need for a heater core replacement from mid winter to warmer weather. But when it started leaking the 2nd time, the leak was much worse then the 1st time but the weather was also much nicer. Didn't have an inside shop area at the time.
In your case, just use the radiator drain and make room for the proper amount of premix. Make sure the instructions are referring to the amount needed for a full system and not the amount needed per gallon of system capacity otherwise your mix will be too weak.
Karl kostman
922
Fargo ND
Jack I had a leak in the radiator on my M977 HEMTT and I was at a show when I noticed it and had to drive 75 miles haome after the show take it out and fix it right I know its not fun BIT
Matt5
Banned
214
Stop leak 100% does work, I would use blue devil it costs money but you get what you pay for.
That being said, you should replace the rad, if you do not have the money or can not do it right now for some other reason, I would add if you can until replacement, if that is not doable then I would use the blue devil but I would use any stop leak as a last resort. The cheap garbage will plug stuff up, good junk will not...
Oh and someone will contest me on this, we had a flatbed with a bad rad, no way to get the rad same day... put in blue devil, followed directions, leak stopped until new rad came... this was years ago, truck runs fine and has great heat still today...
I've used it in my vehicles just trying to make it with head gaskets etc... + 1 again worked great.
dependable
188
Tisbury, Massachusetts
Stop leak products will not be much of a fix if radiator is rotted out or badly damaged. But they do work long term for small holes in otherwise solid radiators. Blue Devil is the best one I have used as well, and has the benefit of not adding solids to cooling system the way some others do.
Had a stick poke into the grill on my 1010 dump truck two years ago. The radiator got a small leak, and I was too busy to take out and solder it up. Added some Blue Devil stop leak and it has not leaked since.
nyoffroad
742
Rochester NY
Not going to work well or last, get a replacement or soldered up.
Matt S
Los Angeles, CA
I just had the same thing happen 2 months ago. I had my original rebuilt at a local shop. It wasn't any cheaper but I know the tank would fit and it doesn't leak.
