Mass Ownage
- 0
- 0
- sulphur, LA
Ok so after several monthes of dealing with a leaky radiator, i'm going to replace it. Anyone know a good source for one? I'm in southern Louisiana.
most good radiator shops can use your tanks and have core part made so you can get a upgraded core to look original. Did one for mine for 320.00 pricey but no tubes welded off or another leak soon from rod and repair service.ok so after several monthes of dealing with a leaky radiator, i'm going to replace it. Anyone know a good source for one? I'm in southern louisiana.
If the tube leak is isolated to only a couple tubes those specific tubes can be closed and it will only slightly decrease cooling efficency.They pinch off and solder closed. the tube splitting issue does however make a statement to the overall condition of radiator. This means at some point sooner than later you will want to replace it. good radiator shops can order by size any core for any vehicle and u would then have fundamentally a new radiator.OK, the radiator shop said they couldn't fix it because the tube was splitting everytime they tryied the repair. Dunno, I'm not a radiator guy. But it looks like I need a radiator.
That's not really necessary.
