- 8,280
- 620
- 113
- Corpus Christi, TX
Another point of confusion based on numerous pm's today. On the right is the MX-6707 which is used for 12 series radios. The 12 series radios are Vietnam era radios that were used up to and including Desert Storm. On the left is the AS-3900 for the SINCGARS. SINCGARS is what is currently being used by the military.
Both are about the same size but the bottoms are obviously different. Quick test is, if you can stand it up on it's bottom, it is an AS-3900. You cannot stand a MX-6707 up on it's bottom. The antenna is different between these two sets.
There is another base also seen in some cases called the Shakespear Low Profile Antenna. It looks like a smaller version of the AS-3900 and the actual antenna looks like wire that is a little thicker than coat hanger wire. I will get a picture of that one out also.
