Radios, aging, and corrosion
papakb
1,195
San Jose, Ca
I've played with these radios for the last 30 years or so and one of the things that kills them quickly is corrosion. There's nothing worse than removing a cover and seeing white powder in a radio. It can be cleaned and repaired but I usually move on to another set because they are less likely to give you fits.
I think what's happening is that over the years the O-rings have flattened out and as the radios sit outside in the sun they heat up and the air inside expands and escapes but then as the radios cool down they draw in outside air and the moisture gets in and stays there. Eventually the corrosion begins. The solution is to replace the O-rings which is a PITA but you can put a little Vaseline or silicon lube on them to help them seal the case.
Just a repair tip.
Kurt Lesser
KG6KMJ
maddawg308
793
Appomattox, VA
Good tip.
Is there any cure for aluminum/magnesium corrosion that has already started? Something you can put on the corrosion to remove or at least stop it?
papakb
1,195
San Jose, Ca
The best solution that I've found is to clean away as much of the corrosion as possible and they put some WD-40 on it then keep it dry. When I was in the Navy we had a spray corrosion inhibitor in OD green cans but I think it was meant for shipboard use and don't have a clue as to how well it would work in electrical equipment.
Wile E. Coyote
81
Lynden WA
I've always wondered if tossing in one of those packed-with-equipment dessicant bags in any radio with the space for such would help solve the problem - or merely exacerbate it. I've had panel corrosion problems on stuff in the past too which you can scrape and clean and etch and repaint...yet it still seems to come back again once started. Very irritating.
tennmogger
556
Greenback, TN
Every piece of British Clansman radio gear I have has a dessicant pack in it. They think it works! :) Typical sealed electronics can be baked at a little over 100 deg F to clear moisture, then add dessicant, and seal.
If corrosion keeps coming back into a piece of electronics then maybe the storage conditions might need thought. Even a 'sealed' case will breathe enough to let moisture ingress. I bought an air conditioner for my radios and they let me use it, LOL
Bob
WB4ETT
Jeepsinker
467
Dry Creek, Louisiana
Best thing for cleaning corrosion from a pcb is a can of liquid wrench penetrating oil and a stuff toothbrush.
And for case corrosion white vinegar works wonders. After treating with vinegar let the aluminum dry naturally, then spray with the red colored battery terminal protectant that comes in aerosol form. I've not done this with military radios, but have done it a lot with C.B. and ten meter amateur radios. People leave them sitting in Sheds and garages for years at a time.
Csm Davis
402
Hattiesburg, Mississippi
When I worked in corrosion control we would wash the gear in a dishwasher then dry it off and spray it down with dry cleaning solution and then bake it in a oven then spray some parts with a shellac or paint while the part was still hot. And yes this was done to electronic equipment, actually avionics electronics as most things can get wet as long as there's no electricity flowing.
