Rattle at highway speed- Engine Governor?
WildernessJeep
89
Huntsville, Texas
My 1984 M936 has a terrible rattle at highway speed- but only when the engine is at governor and I go down a slight downhill. At normal cruise it's fine, but when I go to a slight downhill--only enough to put the engine/driveline in a neutral load-- it will rattle like a bunch of bolts in a dryer. If the downhill is steep enough to put negative pressure on the engine, the rattle stops. If I take my foot off the accelerator, the rattle stops. If I do nothing, at the bottom of the hill when the engine resumes a load, the rattle stops. It almost sounds like a bunch of bolts in the torque converter or a driveshaft rattle, from the front or under the cab. I thought it was in the fan belts, but I replaced all those and still have the rattle. I've checked all the driveshafts and u-joints. Anyone got a quick easy fix for me?
Pic for attention. He doesn't even know how to operate that winch (yet).
simp5782
Feo, Fuerte y Formal
9,322
Mason, TN
What is your governor rpm? Or your speed at which this Is happening?
Some pumps are set to 2150, some are 2450, some 2600
Sound like a dieseling sound cause the governor is defueling
WildernessJeep
89
Huntsville, Texas
Some pumps are set to 2150, some are 2450, some 2600.
Governor at 2200, right at 58 mph indicated. I got it up to 61 once and it felt like I was re-entering earth's atmosphere.
Also, re-read my post. I edited to provide more info.
simp5782
9,322
Mason, TN
On my 816 my front vise rattles the bolts inside the positioning locks when I run it up to speed at times and always on decel.
I have a rattle when the rear PTO is left on and I drive around at speed. I don't ever turn my pto off really it rattles in the rear but it's obvious. Not sure if you have an automatic high idle with your pto or not.
WildernessJeep
89
Huntsville, Texas
I do have an automatic high idle with the crane, but I disengaged it at the air piston and control it manually. I drive around with the transfer case on the floor. Never figured out what the upper (above neutral) position does, other than bang my ankle.
charlesmann
713
Temple, Tx
im betting the tm will say what upper position is. you keep making statements of how, what something is, and 99% can be answered just by reading the tm.
