Guruman
Not so new member
- 494
- 1,076
- 93
- Cody, Wyoming
I'm looking to re-gear my m1078.
I've seen lots of discussion on here about 3.07 versus 2.87 either with or without larger tires. the general consensus seems to be that with my A0, 3.07 plus larger tires is not ideal, and 2.87 with the stock size is not either, at least not without adding power
But here's my thought.
What if I went with the. 2.87 gears in my A0, which normally might be too much gear, but I also stepped down a tire size? Running a smaller tire might have some benefit, a lower overall height would make it easier to get in the shop and avoid overhead obstacles, and maybe have slightly lower aerodynamic resistance. Not to mention it might be easier to get into and out of if that first step were a bit lower.
Being a potential overland/exploration rig, I don't intend on doing any hardcore wheeling in it, mostly exploring dirt roads and back byways so losing a couple inches of clearance under the rig might not be a big deal.
Is there a "goldilocks" zone I could hit? Anyone done this? Other things to consider?
