Real emergency brake
MRDunlap
Asheboro NC
Hello, im currently shopping for my first Deuce, M35a2.
My biggest concern is the brakeing system. Has anybody came up with a seprate "emergency brake" to top the truck in the event of a complete brake failure, air or hydrolic leak?
98G
Former SSG
4,378
That's a fantastic idea. If only...
But nothing workable has presented itself
Dual circuit brakes are the solution. But problematic to retrofit. Clinto is working on a retrofit solution now...
MRDunlap
Asheboro NC
Duel circuit solves the hydrolic leak issue but what about a air leak or line failure? I was thinking something like exhaust or pinion brakes, both have there own issues
98G
Former SSG
4,378
Exhaust brakes are great - I have one on my 1ton Ram. They work better at higher RPM. They're great for slowing, not so good at stopping. Not like a real Jake.
Pinion brakes - the largest disc you can fit just doesn't have enough meat on it to stop you. Brakes convert kinetic energy to heat. 14k @ 50mph melts it before dumping much velocity.
Air leak - you still have brakes, just not assisted.
Line failure - in dual circuit brakes you have half your brake system intact.
rustystud
2,852
Woodinville, Washington
Modern trucks just have dual circuit systems, so why is it worse in a deuce ? Get stainless steel brake lines ( or that stuff Peashooter had) and your good to go.
Robo McDuff
In memorial Ron - 73M819
1,495
Czech Republic
Can't find the pic, but when visiting Commerce Trucks Wildervank (surplus Dutch and Nato army), I saw something approaching that on a different type of truck. That truck used the same type of hand brake which is part of the drive shaft.
What they had done was making a separate air circuit and use that to manage the original handbrake with an air brake work cylinder in between. So more and stronger power to the original handbrake, and in case of air failure, the hand brake starts functioning automatically. The air brake cylinder was mounted on the driver beam of the chassis, a bit backwards of the brake drum on the axle
They claimed it was efficient, certainly as parking brake. How it worked like real emergency brake, I do not know. Probably, only a good dual circuit can be a real "emergency" brake system.
MRDunlap
Asheboro NC
I seem to be stuck on the M35a2, still shopping around. Looking for one i can get a deal on that may need some TLC. All I have found are priced kinda high $6-7k and above
MRDunlap
Asheboro NC
Hydra max bakes sound great. Looking at a M35a2 so i would have to ad a power steering pump as well but is a good option, thanks for the link
Robo McDuff
1,495
Czech Republic
jeepsinker from the above referred link, post 192
... Even if we could just fit the air actuated park brake assembly from a 939 truck onto a deuce, that would be a massive improvement. It might actually stop the truck in an emergency...
That sounds and looks a bit like the Dutch guys were doing.
