Really dreading what this sound could mean... Any ideas?
wisconsinz
Duluth, MN
https://youtu.be/o0UHTgBGyTY
Putting my ear to the oil pan is where it's loudest, or maybe just beyond it, more towards the rear. It stops when I put it into gear sometimes, but usually I can hear it again at random times when I'm driving. I know it leaks oil, and possibly ATF. I haven't had a chance to clean it to figure out where exactly the leaks are coming from, but I recently topped them off. There's nothing in the way of the fan or belts. I'm really dreading how major this could be.
Any ideas? Thanks.
- Ryan
welpro222
Bellingham, WA
Maybe my hearing is bad, but it sounds normal? Video sounds never really work unless its very loud. Anyways first check the torque converter to flywheel bolts, make sure they are all tight. Also check flywheel for cracks or breakage too.
infidel got me
32
Newberry, Florida
noise
The bolts on the bottom of the torque convertor cover should have two rods that run up to each motor mount if I'm not mistaken. If they are missing you will crack your transfer case-- ask me how I know.
Pull the inspection cover and take a look see.
Drock
12
Eatonton GA
Yeah I'm with welpro222, loose torque converter bolts are a common problem with these trucks. I'd check that first.
welpro222
Bellingham, WA
The rods that connect the bell housing to engine mounts, are not that important. But... I installed them on my m1008, because they can hold the tranny to engine when those bolts come loose. Yes this has happen to me on my k5 6.2/700r4, I believe these rods saved my tranny from breaking the housing.
86m1028
17
Murphy TEXAS
Hard to tell from video but it could be an exhaust leak.
Cracked manifold, collector, exhaust pipe near collector.
Loose torque converter bolts, cracked flex plate ect.
cucvrus
10,505
Jonestown Pennsylvania
Exhaust leak at manifold or intake manifold exhaust leak. I had one with a C code set of intake gaskets. And it came from Uncle Sam that way. Black everywhere on right side of engine at CDR valve.
