Really stupid wiper question
warcow105
Lincoln Park, NJ
Any tricks to getting the wiper blades to work well? I just replaced mine and on both sides the center of the blade isn't making good contact. I really loosened them up so they are extra floppy for now and it helped a bit, but this can't be as good as they get.
Mike
warcow105
Lincoln Park, NJ
Everything seems tight and moves correctly, the wiper blades are just not making good contact in the center. Exactly how loose or tight are the screws that hold the blades supposed to be?
Mike
AOR
37
Burtonsville, MD.
without looking at my HMMWV I assume the wiper arms have springs in them to put tension on the arm against the glass?
ken
25
Houston Texas
Can you bend the arm slightly tward the glass to provide extra pressure in the middle?
warcow105
Lincoln Park, NJ
The spring seems fairly strong, but maybe these new blades are stiffer and it could use a bit more pressure. I will give the arms a little bend and see if it helps.
Mike
Dock Rocker
72
Jackson ms
The only way to get them to work really well is to take them off the truck and throw them in the trash. Then cal Kascar or Adventure Accessories and order a set of H1 blades and arms.
It’s literally one of the best mods I have done to my truck.
Also get some rained and slather it on the windshield. That helps a lot.
ken
25
Houston Texas
That is a upgrade I have been planning on myself. I put civi blades on my M35A2 years ago and it was a huge difference. Your right, a good coat of RAIN-X make the wipers almost useless.
TOBASH
3,364
Brooklyn, NY
There are wiper blade helpers that are essentially a spring to add pressure. They fit over the arm assembly of some vehicles.
Amaz0m has them under the following:
"RoadPro V-9009B Black Windshield Wiper Huggies, (Pack of 2) "
There are various configurations. Find the one best for you.
Not stock, but easy and simple and helps until you can purchase the correct equipment.
Best,
T
