Rear AC/ heat on 2007 m1151a1
fastmaxx09
South Carolina
I have a a possible issue. My rear AC blower works great on AC. When I switch it to heat, only the front dash blower works. I haven't had to use the heat yet, so my question is , should the rear blower work when I turn on the heat, or is it just for cooling ? I would assume it should work as it does when I use the ac , but it doesn't blow when I switch it to heat .. The front works fine, just not the rear
