Rear axel brake line fitting
Jeff Cal
Stamford CT
Steel lines are missing that run from the frame crossmember fittings to the frame bracket fitting that connects to the two rubber brake lines going back to the rear brake manifold on the pumpkin/banjo.
Can anybody help me with the thread size? I need the same size male ends to complete the line in what I think is an early deuce at my VFW Post.
Thanks in advance. Jeff
