Rear body mount nut and bolt size?
GixxerSixxer
SLC/UT
I'm installing my airlift bumper and don't have tools big enough to undo the rear body mount nut and bolt. What size socket and wrench do I need to go buy?
Are other big bolts on the vehicle SAE or metric? I need to remove the rear camber shims too at some point. Should I buy both SAE and metric jumbo tools or do I only need one set?
Carrera911
31
Cumming, Georgia
I’m going to be doing this in the coming weeks so I went out and checked for you. It’s a 15/16 which I went out and bought when I installed my front winch. It’s a common size for a lot of the frame related bracketry on the truck. From what I’ve seen all the body and frame bolts are standard with some of the GM powertrain bolts being metric. Harbor freight might have a relatively cheap set but I rarely deal with larger than 3/4 so I bought just the one wrench at autozone for 7-8 bucks.
