Rear brake valve
Matt S
Los Angeles, CA
So I've found something I don't really understand when I removed the bed. It's in the brake system and tied to the rear axle.
I beleive it's a proportioning valve that adjusts to the load on the truck. I'm not sure what to do with it. Can I just unhook it from the axle and drive it like that? Do I have to bypass it if I unhook it? If I weren't planning on a lift then the I'd probably just leave it alone.
cucvrus
10,502
Jonestown Pennsylvania
WOW that truck is in great shape. It still has the factory part number ink stamp on the muffler. As I read here most guys are tossing that valve. They have a GM service bulletin that describes how to eliminate it. I am sure someone will post it. I don't eliminate it I went thru great pains to get a new one on a restoration I was doing. IMHO it does work. And if it were me I would measure the angle when it was unloaded and duplicate the same angle after the lift unloaded. This would be by adding the appropriate length to the arms/arm to maintain the antilock rear wheel function. That's just me. I know the valves work I drove a truck without it and rear wheel lock. That was the reason behind it. We could debate all day. Good Luck. Nice looking truck. I assume you removed the service body. I would have done the same and have. That makes a nice pickup truck cab chassis.
