Rear bumper mount shims dimensions?
JO-0321
32
Boise, ID
Ordered these shims online but they’re delayed and I really want to wrap this bumper project up over the weekend. I plan to cancel the order and make my own.
Can anyone tell me the dimensions of these shims? Length/width and (most importantly) thickness. I can figure out the holes on my own.
Thanks!
cwc
156
Sweeden, KY
Here are some pics of one off a M1152, which should be a factory installation and a genuine part, but the part number (12338164) is painted over. It measures 3.00 x 3.625 x 0.141" thick with the paint. I included the scale in the pictures since the hole locations are not exactly symmetric with the edges...no idea if this is intentional or just manufacturing slop. Holes are just a bit over 0.500" diameter.
Airlift bumper shim - 3.00 short dimension.jpgAirlift bumper shim - 3.625 long dimension.jpg
JO-0321
32
Boise, ID
CWC…thank you for the reply! I just received these specs yesterday. Lines right up with what you provided. For everyone’s reference:
The government specs for the spacers are as follows:
HOLE DIAMETER0.531 INCHES NOMINAL
OVERALL LENGTH3.680 INCHES NOMINAL
OVERALL WIDTH3.060 INCHES NOMINAL
OVERALL THICKNESS0.1196 INCHES NOMINAL
CENTER TO CENTER DISTANCE BETWEEN BOLT HOLES ALONG WIDTH1.437 INCHES NOMINAL
CENTER TO CENTER DISTANCE BETWEEN BOLT HOLES ALONG LENGTH2.562 INCHES NOMINAL
OUTSIDE EDGE TO BOLT HOLE CENTER DISTANCE ALONG WIDTH0.840 INCHES NOMINAL
OUTSIDE EDGE TO BOLT HOLE CENTER DISTANCE ALONG LENGTH0.560 INCHES NOMINAL
BOLT HOLE QUANTITY4
MATERIALSTEEL
  • Like
Reactions: cwc
