Hmmv4me
- 13
- 8
- Carson City, NV
I decided to remove the rear camber shims on my M998 to get a strait camber. Wow, those rear upper control arm brackets are a bear to remove by yourself, good thing I have 3 elbows...... Anyway, I know this topic has been beat up a bit around here, but I couldn't find the torque specs on the 4 upper control arm bracket bolts. I searched every TM I have and couldn't even find the topic of replacing them. Someone mentioned 260 ft lbs for the bushing bolts, is that right? I definitely need a bigger torque wrench. I put it back together to see how it looked and without putting it on a rack, it look pretty strait. I was a bit shocked at how much that effected the toe. I now have 2 inches of tow out, hope I can adjust it back in enough.
