Rear Differential Fill Question - M1009
cmroles
Phoenix, AZ
I just changed the fluid in my rear differential. According to the LO the rear 10-bolt should take 5.4 pints of 80/90. I got almost, but not quite, 5 pts in before the new GO started coming back out of the fill plug. At this point its closed back up, but am I going to have problems if I leave it filled to the bottom of the plug-hole?
I know most people say to leave it 1/2" or so below the plug, so I'm just curious if I've created a potential problem.
DokWatson
Wasilla, Alaska
Gov-bomb differential doesn't use clutch packs like a regular limited slip, no additive required.
Its supposed to be filled up to the fill hole. Axles have breathers, you can't hurt it by 'overfilling' it.
cmroles
Phoenix, AZ
I just fill it up till she blows .. let it drain out till its just at the top of the fill. Plug her and go.
Perfect. I was just worried that I'd damage by overfilling.
The truck only has 26,000 miles on it, and the gear oil that came out looked like vintage 1984...
gvaneck
lansing il
I need to drain out my rear fuild and i was wondering what gasket I should get for the m1009 and if the front and rear seal is different
I JUST did this to my 1009- the front and rear have different seals.
Front-Gasket GM# 458860
Rear-Gasket GM# 26016662
I went to Oreilly's and gave them the GM numbers and they had them in stock...hope this helps.....:grd:
ChiefMinion
12
Prescott, AZ
Front Rear Differential Gasket
1986 M1009
If it helps anyone, the Fel-Pro gasket numbers for the axle housings are:
Front: RDS 55075
Rear: RDS 55028-1
Note that when I walked in to NAPA, and asked for the front gasket, their computer specified the rear. Not a problem since I needed a rear anyway. They are NOT the same.
ryan77
56
Cary IL
Most gear oil has the additive in it! look on the bottle unless you get the cheap stuff like costal, valveoline at autozone has it in it.
idM1028
Somewhere in Nebraska
:ditto:
Yep, love the valvoline. Mostly because I can use it in the rear AND the front of the M1028 :grin:
You shouldn't have any problems with overflowing. I just changed out my front and rear diff fluid. I've always just filled up my fluids till they start pouring out the fill plug and have never had a problem.
