Rear fender mount ac condenser???
Mjvaden
Madison ga
Can any one tell me if this ac condenser that mounts inside the rear right fender will work with a reddot ac kit? If so is it plug and play or to modifications have to be made to make it work?
DatGuyC
21
Essex, Maryland
Interested also. That looks like a passenger side one, I know they also made drivers side versions. I think I've seen trucks with condensers on both rear fenders also.
Retiredwarhorses
4,054
Brentwood, Calif
I have done factory air and red dots...and have been asked to do this same conversion, I declined, due in part that the customer would be paying for me to learn. Attached to that condensor is the dryer, a harness runs to the Evap unit in the passenger compartment where the old heater core and blower is now. It could be done...I guess, you would need to fabricate up your lines of course to feed the unit. The right fender is where the condensor goes for a 2 man truck, for a 4 man it gets one in each fender well, the left fender well is for the rear compartment...but wouldn't make a diff for a red dot setup....I would go with the left side.
you will need to cut the fender for the intake and screen...and you will need the special bracket for mounting it, it's not included with those units.
