Thanks guys I all ready had the trany down, install a nitrile seal on, and ran the engine for half hour, and start leaking since that seal was a NOS like the lip was not tight to the shaft, so got the floruelastomer install it dry out all the area to determine source if any after half hour of running the engine since a very little amount of oil, but a total dry condition, so that why i ask if may be the oil is too thin that is ziping out, I allso going to try a new gasket that is made out high temp rubber about 1/16" thick, I will report back to base with result.
P.D: I am an industrial ingineer for food processing companies, and I always surronded by innoveted material, engineering so I like to experiment.
Thanks.......as you were folks
![Big grin :D :D](data:image/gif;base64,R0lGODlhAQABAIAAAAAAAP///yH5BAEAAAAALAAAAAABAAEAAAIBRAA7)
