Michael
- 24
- 38
- Fulton, MS
Does the deuce have a rear axle oil seal like the one in the front axle? I am referring to part number 7521789.
http://www.odiron.com/store/product_info.php?cPath=4_48&products_id=205
My rear axle is leaking gear oil. From the trouble shooting:
DIFFERENTIAL LEAKS OIL
Check axle seals condition. Inspect drum for presence of gear oil.
If gear oil is present in or around drums, replace axle seals (para. 7-7).
Which take you here:
7-7. FRONT AXLE OIL SEAL ASSEMBLY REPLACEMENT
This task covers:
a. Removal b. Installation
INITIAL SETUP
APPLICABLE MODELS REFERENCES (TM)
All TM 9-2320-361-20P
SPECIAL TOOLS
Puller, mechanical,
MATERIALS/PARTS
Oil seal assembly
PN 8708740
Inserter, oil seal and retainer, EQUIPMENT CONDITION
PN 7083258 Front axle shaft removed (para.
Using mechanical puller, remove oil seal assembly (1) from axle housing (2). Discard
assembly (1).
b. Installation
Using oil seal inserter, install new oil seal assembly (1) in axle housing (2).
I know about the cork keyway and the inner and outer seals, I just want to be sure I am not missing something. I have also been to OPCOM's excellent web site on the subject.
This task covers:
INITIAL SETUP
SPECIAL TOOLS
Puller, mechanical,
MATERIALS/PARTS
Oil seal assembly
PN 8708740
assembly (1).
b. Installation
