rear shackle mounting points
m16ty
211
Dickson,TN
A 5-ton rear shackle mount will take the same size shackle as the front on a deuce.
73m819
319
gainesville, ga.
no 1", the deuce should also use 1", the first gasser deuces used 15/16" pins F/B
I had a set of those 15/16 brackets, went to use them, could not figure out why my 1" pins would not work, ecen a BFH, till got out the tape, DA, 1" does not fit a 15/16 hole
