Rear shoulder belt install
Dayron84
15
Tennessee
I purchased a NOS rear shoulder belt kit for the humvee ( a little added safety for the kids) I know I have to cut the rear curtain for the bump outs but I’m not clear exactly where to cut. If anyone else has done this I sure would appreciate some advice so I don’t screw it up
juanprado
2,847
Metairie/La (N'awlins)
4 man rear curtains usually have the extra piece pocket already on them, best to find one with it as the kit will have snaps for it and to keep you better weather proofed
Dayron84
15
Tennessee
My curtain has the pocket. I just need need to know where to cut
SchmidtLegal
23
Canton/TX
On the back of the pocket is a horizontal retaining strap of plastic, cut those off to expand the pocket. On the inside of the curtain, cut slits on either side of the inside of the pocket to allow for the seat belt harness to slide freely. Its counter intuitive, but its what has to be done. once you make those cuts, it should slide over the aluminum seat belt bracket and attach in the back with the thumb twist.
juanprado
2,847
those go under the fender to reinforce the bracket that holds the reel. Instructions are located in the tm's under the mwo ( maintenance work order updates)
I don't recall the number but they all should be listed with links to the individual ones.
Dayron84
15
Tennessee
Makes sense now. Thanks!
