01flhtc
- 0
- 0
- Knoxville, MD
What is the correct spanner to get and where to get it to disassemble and assemble the rear brake drum? I have searched but, I am unable to find the information.
m1008which truck?
Pound head of torque of course. You didn't know?How did you properly set the bearing preload with your screwdriver?
And you are absolutely correct. Feel is far more important than torque, for one the bearings and their races are hardened steel, the threads on the nut and axle housing have **** near ZERO deflection from 50 foot pounds, considering area of thread engagement and cross sectional areas.Well for starters it wasn't that tight to begin with. Which is why I was able to easily tap it out with the screw driver in the first place. Secondly I've always done bearing preload by feel rather then a torque wrench. A torque wrench can't feel if the wheel is too loose or too tight. Just my opinion...
