Rear square drive studs
coder123
Tamaqua pa
I'm sure this has been covered but I'm talking to guy a who says I must use the square drive studs on the rear of my M54 when I put super singles on....That's fine and I will but does the square drive just tighten up to the hub then? And then the outer nut tightens to the rim? Please someone clear this up.
98G
Former SSG
4,803
The 5ton combat wheels or the LMTV wheels either one will be fine with the standard lugnuts and wheel studs.
HEMTT rims would require offset lugnuts or longer wheelstuds.
What size tires do you plan to use?
dmetalmiki
2,034
London England
When I fitted out my M35A2 with AEC Militant wheels and tires (200x20) I did not use the square st5uds, that is unsafe. I made 'Adaptor plates' to fit the original 6 studs, Using the original wheel nuts as well.and the plates (chamfered) carried the 10 stud AEC wheels. Using chamfered nuts and bolts I made.
tobyS
840
IN
Necessity being the mother of invention!
